c70 transmission nightmare
Old Aug 12, 2011 | 09:25 AM
volvonutjob's Avatar
Question c70 transmission nightmare
Can someone tell me how the gear shift solenoid tells the ecu what gear it's in I have a problem with the transmission in D it changes gear from 1st to second then losses drive if i start in L then go to second then shift to D drive works. The fault code comes up with PO785 wiring shift/timing solenoid ECM/PCM TCM I also get P1618 TCM MIL ON request circuit high I have looked at the shift solenoid at the base of the gear shift seems to be working fine it retracts when brake is depressed Anyone got any advice
Thanks in advance
Old Aug 12, 2011 | 06:48 PM
fcpgroton's Avatar
Former Sponsor
Welcome to the forum.
Not sure exactly how this works. Have you posted this question in the C70 section?
Old Dec 13, 2011 | 08:46 AM
joechadwick's Avatar
Hey you'll find the shift solenoids under the side pan on the transmission.
picnic39
Jun 24, 2009 10:46 PM
limelightsc
Mar 14, 2009 01:11 PM
muscle car mike
Jan 21, 2009 05:18 PM
pmpalma
Feb 22, 2008 08:26 AM
funnyguy44444
Jun 23, 2007 04:36 PM
