C70 turbo questions
Old Aug 17, 2006 | 04:43 PM
peter_jf's Avatar
Default C70 turbo questions
Help,,,
Here is the situation. I have a 1998 Volvo c70 HPT. Recently, I was on the freeway and I was doing 70mph and went to pass and punched the accelerator and there was a weird turbo lag and my check engine light went on blinking then remained lit. Took it to the dealer and he said that is was a cylinder not firing properly. He advised not to worry and just take it easy before its 125k mile tune up. Well since then, 4 weeks a ago,,, I have noticed that if I take it out of economy mode and into sport mode, I get a weird hesitancy when I kick in the turbo. Almost like if a car is running out of gas. Is my turbo going out?? I checked my plugs and they looked great minus the normal wear and tear. During 125k tune up,,,, do they do something to the turbo such as adjust is? Also,,,, when does major belt repair happen????
Side note: I also have been experiencing a weird noise coming from the engine (((almost sounds like a turbo whine when it is cold.))) It goes away after the car warms up to normal operating conditions. But if I drive it after I start it,,, I here the whine until it gets up to certain RPM and then is just goes away. Almost sounds like a gas releasing. Is this the turbo as well?
Any help or the certain same problems with other members would be well received. I am scared that these are a tell tale signs of some sort of major problem. I hope it is minor,,,, like I said,,, I can drive the car fine until it kicks in the turbo and then the "Spitting Sluggish†comes into play and the annoying whiny until the care warms up. All this has been getting progressively worse by the way.
Thanks,,,
Peter
Old Aug 17, 2006 | 09:24 PM
Default RE: C70 turbo questions
I would do the tune-up and see from there.
Timing belt on the 1998 is 70,000 miles.
Old Aug 19, 2006 | 10:04 PM
c70_joe's Avatar
definatly have a tune up i heard a horror story of someones turbo blowing took a chunk out of the engine
Old Aug 20, 2006 | 02:54 PM
S70driver's Avatar
Don't want anything flying out of the car that is for sure.
Old Oct 29, 2006 | 04:35 AM
C70's Avatar
C70
ORIGINAL: peter_jf
Yea im hearing the same whine currently and never heard it before.I got alittle advice from another fourm that syas it the Pulsed "Secondary Air Injection System" thats could cause the sound and it amy need replacement.
Heres the link...
http://www.volvospeed.com/Repair/airpump1.php
Old Oct 29, 2006 | 10:42 AM
The Air pump is normal to come on when the car is cold.
That is how it is designed to work.
Phil 850
Jul 25, 2012 10:01 PM
AnEskimo
Sep 25, 2010 08:32 AM
snulma1
Jul 12, 2006 03:05 AM
boostedvolvo5645
Jun 28, 2006 12:34 AM
snulma1
Jun 19, 2006 03:52 PM
