Clutch went out need help with a rough diagnosing
Old Jul 9, 2010 | 11:58 PM
allanburns's Avatar
Post Clutch went out need help with a rough diagnosing
Went to get in my 2000 Volvo c70 after work and saw a medium sized puddle of what smelt like break fluid under my car. I got in and pushed the clutch in and turned her over went to let up off the clutch and it didn't come back up.. so i have no clutch. Looked underneath my c70 and saw some leakage on the back of the tranny where it is closest to the ground and fire wall. what could be wrong with her? i have heard slave silender? any thoughts or some helpful suggestions would be great
Old Jul 14, 2010 | 10:26 PM
ehinson's Avatar
Default Re: Clutch went out need help with a rough diagnosing
Did you get this fixed yet?
Old Jul 21, 2010 | 09:28 PM
allanburns's Avatar
no its has not any sugestions as too what it could be?
Old Jul 24, 2010 | 05:24 PM
Maybe the clutch master let go.
If it was the slave it would come out of the hole between the tranny and motor.
Old Jul 26, 2010 | 07:34 PM
allanburns's Avatar
Hmmm, well the Slave is in the bell housing and there was leaking spots on the bottom of the tranny, i assume its the slave any way i can test the master cause iam broke atm
Old Jul 26, 2010 | 09:34 PM
Well you can try to bleed it and see if you can get any pedal at all. Or when you manually try pumping it does it just shoot fluid out the bottom?
Old Aug 3, 2010 | 10:56 PM
allanburns's Avatar
nope it shoots nothing out the bottom all the fluid is outta the line i believe
geckthx
Jun 12, 2014 10:55 AM
xray
Dec 21, 2012 09:08 PM
avanhaselen
Nov 10, 2011 09:15 AM
bobbyleethomas
Oct 10, 2010 07:51 AM
mateo
Mar 1, 2006 10:29 PM
