Coolant leak
Old Apr 22, 2009 | 07:00 PM
MoneypitC70's Avatar
Default Coolant leak
I searched the forum and could not find an answer so I'll post this question....there is a small coolant leak from the upper radiator hose and the overflow hose. The thermostat and upper hose has been replaced, but there is still a coolant leak. Do the radiators usually fail in these areas (around the hose outlets)?
It almost seems as though there is excess pressure in the cooling system forcing the coolant out, if that makes sense. I believe the new stat opens @ 87 degrees and I have the Conv lt.
Old Apr 22, 2009 | 07:47 PM
The radiators are known to crack.
no1pony
Sep 3, 2011 06:45 AM
aru5016
Jun 19, 2011 12:26 AM
cmayo313
Mar 18, 2011 12:09 PM
Ahmed
Aug 30, 2009 01:58 PM
timk
Nov 16, 2007 08:33 PM
