steering rack replacement
Old Apr 22, 2009 | 11:15 PM
yarr's Avatar
Default steering rack replacement
Hey everyone. I have a 2001 c70 convertible with the 2.4t. I have been having some power steering fluid leakage so I went to volvo and they quoted me like 1800 to replace the steering rack. That is nuts. I found a rack online here. http://www.autopartspoint.com/addtoc...80-00853.html#
and was wondering how hard would this be to do myself. One issue is I have no manual to use. Any advice on manual or how-tos would be awesome.
Old Apr 22, 2009 | 11:32 PM
ICE's Avatar
ICE
When turning your steering wheel do you get a knocking sound or feel like something is grinding and cracking ? thats what im getting and most likely its the steering rack too...dammit ! haha
sorry what I was getting at is that it might not be the steering rack that needs to be replaced.
Old Apr 23, 2009 | 05:56 AM
mick1232's Avatar
Volvo might be trying to rob, you go to different garages for other opinions
Old Apr 23, 2009 | 08:20 AM
ICE's Avatar
ICE
haha I dont think thats in Question ! they are terrible.
Old Apr 23, 2009 | 02:28 PM
reg's Avatar
reg
Volvo replaced my rack under warranty for the reason of a leak. I have an old 02 c-70. After that replacement it went on and the pump was replaced and then the resovoir. Interesting. At any rate it's no big deal changing a rack out. I am sure TECH will comment on the appropriate steps.
As to the cost of parts.........most all European autos charge an arm and a leg for parts but by the same token, they are most generally superior in quality to aftermarket. You might want to check on the cost of a re-build.
r.
Old Apr 23, 2009 | 07:13 PM
You have to support the motor and drop the rear subframe to replace the steering rack.
Old Apr 24, 2009 | 02:42 AM
yarr's Avatar
Default drop the sub frame.
Well there is only a leak and no crunching or knocking. I will pursue checking out other causes and fixes. Otherwise I don't think i am prepared to drop the subframe and all the other stuff tech mentioned. Jb weld perhaps.
timmins
Sep 28, 2022 02:00 PM
maduko
Nov 21, 2011 09:03 PM
redbriq
May 5, 2011 10:40 PM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
