Desperately need pic of a C70 antenna ring harness
Old Apr 30, 2017 | 08:45 AM
RSKRWD's Avatar
Default Desperately need pic of a C70 antenna ring harness
Hi all,
I need a picture of the harness that connects to the antenna ring. I'm helping a friend figure out a starting/stalling issue with his '04 C70, and we took the connector apart to rebend the female contacts a bit tighter. Unfortunately the wires pulled back out of the green connector body before we got the connector snapped back closed, so now I'm not sure which wire goes where in the connector.
I suppose a wiring diagram or just an explanation of the wire colors could also work. By the way, the wire colors on this car are red, orange, pink with white stripe and pink with black stripe.
Thank you very much for any and all help! When I'm done I'll be sure to make a detailed post outlining what all we did to (hopefully) successfully fix this starting/stalling issue, which I'm sure will help another member down the road.
Attached Thumbnails Desperately need pic of a C70 antenna ring harness-img_0074.jpg   Desperately need pic of a C70 antenna ring harness-img_0073.jpg
Old May 3, 2017 | 09:07 AM
RSKRWD's Avatar
Darn, I was really hoping for more help with this.
I really need a picture or two of this harness so I can help my friend get his car back on the road. I'll pay a $20 bounty via Paypal to anyone that can either find or take a good picture of the harness/connector. It only takes a minute or two to pop the steering column cover apart to snap a picture...
Old May 14, 2017 | 05:43 PM
RSKRWD's Avatar
It's crazy how nobody here wanted $20 for 3 minutes of work. Anyway, I finally found a C70 in a local junkyard and was able to snap some pics for myself. Posting them here in case anyone ever needs them in the future.
Attached Thumbnails Desperately need pic of a C70 antenna ring harness-img_0077.jpg   Desperately need pic of a C70 antenna ring harness-img_0076.jpg
mowntnbkr
Mar 21, 2023 09:11 PM
jcmoyer2004
Mar 11, 2017 12:44 PM
pierce
Sep 29, 2014 06:23 PM
Heike
May 4, 2010 11:50 AM
luvmybassetthound
Jun 30, 2008 06:04 PM
