Fuel system problem.
Old Mar 22, 2015 | 03:57 PM
edlanglais's Avatar
Default Fuel system problem.
I made the foolish mistake of running out of gas. Well technically, I did make it to the gas station in time. However, two minutes after the last fuel bar disappeared, I behain hearing sloshing noises. After I got fuel, the sloshing noises continued. And now I'm getting terrible fuel economy.
Old Mar 23, 2015 | 09:04 AM
what year is your car? its possible you picked up something from the tank that is getting into the tank pick up (there's a screen inside the tank) or fuel filter. Otherwise it may be a bad tank of gas or a pump that's on its way out... You can try changing the filter on your own or test for fuel pressure at the injector rail (there's a small schrader valve there).
inilegna
Sep 25, 2013 03:27 PM
brian@travispace.com
Jul 23, 2011 06:17 PM
bspark1
May 24, 2010 12:12 PM
virginiabowen
Sep 29, 2008 05:31 PM
