Grease front suspension/steering
Old Oct 27, 2010 | 03:19 PM
charlie ox's Avatar
Default Grease front suspension/steering
We have grinding/squeeking in front end when turning sharp when parking. Are there grease points up there that should be greased when getting an oil change? I doubt whether this has ever been done.
Old Oct 27, 2010 | 06:47 PM
There should be some plastic steering stops on the front of the lower control arms. Put some grease on them and you should be fine.
Old Jul 10, 2017 | 06:12 PM
washdup's Avatar
Reviving an old thread because I have the same question. My '98 V70 squeaks horribly in low-speed turns. It is not the steering column bushing. The sound is clearly coming from behind the left front wheel as the steering causes the suspension components to articulate while under load. With the engine running, it is very difficult to isolate the source of the sound. It does not happen at full lock, so I doubt it's the steering stops.
Mooneyfly
Jun 12, 2011 07:52 AM
grigalid
Aug 25, 2010 08:22 PM
FirstV70Volvo
Jan 1, 2009 10:08 PM
steveHut2
Mar 7, 2006 09:18 PM
