HARD TO START 1999 C70
Old Jul 13, 2006 | 03:23 AM
map1470's Avatar
Default HARD TO START 1999 C70
HARD TO START INTERMITTENTLY, WHEN YOU TURN IGNITION KEY ON BEFORE START ARE YOU SUPPOSE TO HEAR FUEL PUMP BUZZ A LITTLE? I HEAR NOTHING, MAYBE FUEL PUMP OR FUEL FILTER? IS FUEL PUMP HARD TO CHANGE? WHERE CAN I PURCHASE FOR RESONABLE PRICE?
Old Jul 13, 2006 | 03:51 AM
Default RE: HARD TO START 1999 C70
The pumps are Very hard to hear on the C70.
What exactly does it do?
It cranks over but doesn't start?
It could also be the Key or Antenna ring (Ligth around igniton switch) bad.
Next time it happens take the key out and turn it 180 degrees and then try again and see if it starts right up.
Old Jul 13, 2006 | 10:48 AM
map1470's Avatar
WHAT HAPPENS, KEY TO START, RPM'S RISE ABOVE 1000 IMMEDIATELY AND THEN DROPS TO ZERO, THEN IT TAKES SEVERAL ATTEMPTS TO START. SOMETIMES WHEN I CAN ANTICIPATE IT HAPPENING I GIVE IT A LITTLE GAS, THEN ENGINE RPM'S RISE TO 1500 AND THEN STABILIZES BELOW 1000 AT NORMAL. THANKS FOR THE TIPS TECH , YOU ARE DEFINATELY AN ASSET TO THIS FORUM. WHAT STATE YOU LOCATED IN ?
Old Jul 14, 2006 | 09:13 PM
I am in Florida.
If you have a spare key try using that as well and see if it still happens.
Old Jul 17, 2006 | 11:43 AM
map1470's Avatar
TECH I TRIED A DIFFERENT KEY AND STILL HAVE SAME PROBLEM. BY THE WAY I LIVE IN MIAMI AND WORK IN FORT LAUDERDALE. THANKS FOR YOUR INFO.
Old Jul 18, 2006 | 12:16 AM
Try the Antenna and see if it gets better.
Old Jul 18, 2006 | 09:19 AM
map1470's Avatar
WHAT'S THE ANTENNAE? CAN I CHANGE THIS MYSELF?
Old Jul 19, 2006 | 12:03 AM
The Antenna is the Little light around the ignition switch.
Yes you can replace it your self. All you have to do is drop the covers for the steering column.
Old Jul 19, 2006 | 10:07 AM
map1470's Avatar
THANKS FOR INFO TECH. IS THEIR A ONLINE SOURCE TO PURCHASE ANTENNAE RING?DO I HAVE TO GO TO DEALER? IS ANTENNAE RING CORRECT TERMINOLOGY? WHAT'S APPROXIMATE COST?
Old Jul 19, 2006 | 09:42 PM
Sorry I forget the cost but think it can only be bought at the Dealer.
tworusty
Mar 29, 2015 05:03 AM
securisign
May 31, 2014 11:10 AM
swampcollie
May 8, 2014 09:35 PM
daver80
Jul 13, 2009 10:19 PM
jerryman
May 23, 2006 01:19 AM
