Hood will not open!!!
Old Dec 20, 2009 | 05:56 PM
BadAzzStang's Avatar
Default Hood will not open!!!
When I pull the handle the driver side unlatches but the passanger side does not. Anybody have any idea what I can do to get it open ?? I'm in a bad spot because I need a oil change, need to add coolant, and replace 2 fuses and replace the air filter. I'm very fustrated
Old Dec 20, 2009 | 10:46 PM
mkc70's Avatar
Cable could be stretched slightly. Try it several times, possibly with a helper at the front of the hood. Also could use pliers on the cable to pull the release a smidge further. Just be careful not to kink or damage the wire cable. Mine tends to stick on the driver's side the first attempt if I do not open the hood frequently enough.
Old Dec 21, 2009 | 09:10 AM
I meant to say that I have tried everything including what u said to try to get it open. I have lifted on that side while another person pulled the release. And nothing. I tried the pliers by my self. Maybe I'll try with 2 people but I'm not having much luck. The locking mechanism feels like it's disengaging when I pullit on both sides if u have your hand on the hood.
Old Dec 21, 2009 | 10:19 AM
mkc70's Avatar
Normally I will push down and relatch the hood on both sides. If you try and do the hood release with one side unlatched from my experience the stuck side will not release. Maybe hit Tech with a message and see if he has a special method to release both sides.
JeannieBeannie
Mar 6, 2019 01:29 PM
MDUBBSS70
May 28, 2014 09:02 PM
Red Tractors
Aug 20, 2013 10:33 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
