How to Install a BOV yes im a fat noob
Old Jul 28, 2009 | 02:22 PM
SeeSevenTea's Avatar
Default How to Install a BOV yes im a fat noob
Well I have a 98 C70 hpt and was wondering since im new to cars does anyone have a write up or some good instructions on how to do this and wht are some good bov's?
Old Jul 28, 2009 | 03:09 PM
S70driver's Avatar
Welcome to the forum.
I will say this a BOV on our cars are worthless. We aren't making enough power for them to be useful. With that said if your an automatic it will only go off when you let off the gas and for the split second it vents to the atmosphere you'll run rich. The only thing you will gain is the sound, but again only when you let off the gas.
Some BOV Ideas...
1. HKS SSQV
2. TIAL
Stay away from the TurboXS brand.
Some Mounting Ideas...
1. With the included and or bought extra Aluminum flange have that welded to your Upper IC pipe (The one going over the engine), then run your vacuum line.
2. With the BOV and a bought extra "T" adapter cut the Upper IC turbo hose at the intercooler and insert the "T" adapter in the two pieces of the turbo hose clamp it down tight attach the BOV to the "T" adapter and run your vacuum line.
3. If it is Aluminum do the same as number one but at the Throttle Body pipe.
Old Jul 28, 2009 | 03:27 PM
Thanks ill probably stick with the stock recircs untill i get the 19t
Old Jul 28, 2009 | 03:59 PM
S70driver's Avatar
Even with a 19t it wouldn't be worth it. Your not going to be running enough power to make it useful. It will still only go off when you let off the gas in an automatic and will still run a little RICH for the split second it vents.
Basically it is a glorified noise maker on your car. Spend your monies on something that will make your car faster, brake better and better suspension or cosmetic.
Trust me when I say this you'll get tired of the sound after about 6 months.
Old Jul 28, 2009 | 04:22 PM
Alright i'll take your advice and get a set of anti sway bars instead thanks for your help.
Old Jul 28, 2009 | 04:40 PM
TIPSP's Avatar
Got Boost?
you will enjoy the bars more than the psssshht sound.
if you want to hear the stock cbv, just put a cone filter on your maf.
Old Jul 28, 2009 | 05:01 PM
how would that make me hear it?
Old Jul 28, 2009 | 05:35 PM
TIPSP's Avatar
Got Boost?
the stock intake box is restrictive and prevents you from hearing the turbo spool or the cbv. when you let off the throttle, the extra charged air is released into the turbo inlet (right before the compressor wheel). the cone filter makes it a lot louder.
youtube has some videos about this. mine is pretty loud.
I can get a video up.
Old Jul 28, 2009 | 05:47 PM
TIPSP's Avatar
Got Boost?
Video quality sucks.
http://www.youtube.com/watch?v=IYo1MDbxmZE
Old Jul 29, 2009 | 05:19 AM
Thats exactly what im looking for so I should just go with cold air? Or where did you get yours?
Old Jul 29, 2009 | 06:16 AM
S70driver's Avatar
FYI, no one truly makes a real CAI for our cars. At least not the 70 series models...
With that said we do have available what are called SRI's or Short Ram Intakes. IPD USA and EuroSportTuning (EST) both have a version of this. Pretty pricey for what you actually get. I have the EST version and I like it a lot. However I didn't pay for it, it was bought for me as a gift!
You could buy either of those mentioned above or make your own. Create your own heatshield and buy whatever cone filter you'd like. Probably could be done for under $100 I would say.
I believe the person that posted the video made his own SRI system there.
Old Jul 29, 2009 | 12:55 PM
TIPSP's Avatar
Got Boost?
Yep, I built my own. https://volvoforums.com/forum/showth...866#post171866
It is a short ram setup with a custom heatshield. I call it a CAI, because no engine heat can get to my filter.
Old Jul 29, 2009 | 01:48 PM
So this is probably a good first mod.
Old Jul 29, 2009 | 01:51 PM
TIPSP's Avatar
Got Boost?
maybe. It is what I started with. you wont gain much from it just by itself other than the sound.
if you wanted to spend the money, swaybars are really good. or lowering springs.
Old Jul 29, 2009 | 02:10 PM
My question is how would i put a ram intake without making the check engine light show?
Old Jul 29, 2009 | 02:48 PM
TIPSP's Avatar
Got Boost?
it doesnt set of the CEL. Everything is still connected.
Old Jul 31, 2009 | 05:30 AM
  #17
ITS ME DAVID's Avatar
but this sounds so much better..
http://www.youtube.com/watch?v=7spoLsjrbTk
Old Jul 31, 2009 | 09:48 AM
  #18
S70driver's Avatar
Yea sadly that car sounds like it is a manual transmission... But more then likely the OP here has a automatic transmission. So like I said before it will only go off when the OP lets off the gas. Trust me I had a BOV and it gets really annoying after six months.
Old Jul 31, 2009 | 11:12 AM
  #19
TIPSP's Avatar
Got Boost?
that is Mike's car in AZ. It is a modded AW-71.
It is an auto. That thing is stupid. No traction in 3rd gear... lol.
We shift them like a manual without a clutch
Old Jul 31, 2009 | 11:48 AM
  #20
S70driver's Avatar
Either way in an automatic a BOV is worthless and on our cars we don't make enough power even with minor mods to benefit from them. It is a glorified noise maker and that is about it.
darrellweiss98789
Feb 1, 2013 01:04 AM
hawaiivolvo
Aug 31, 2010 09:02 AM
SMTurbo5
Apr 16, 2009 06:45 PM
Volvo V70R
Apr 27, 2007 05:21 PM
