how to work the anti-thieft
Old Nov 11, 2007 | 05:48 PM
PANTYEATR's Avatar
Default how to work the anti-thieft
ok, normally i can just lock the driver's door with the key, the interior lights fade out and the LED starts blinking. now it's not doing that anymore, i'm sure it's not broke, just something i did or did do.
so how do i work it and no i don't have a keyless entry remote yet [&o]
Old Nov 11, 2007 | 06:51 PM
Default RE: how to work the anti-thieft
You don't need a remote for the alarm to work.
The alarm should come on once the car is locked.
Do the interior lights stay on?
Old Nov 11, 2007 | 09:17 PM
PANTYEATR's Avatar
yes the interior lights stay on and then fade out. usually they fade out as soon as i lock the door with the key.
Old Nov 11, 2007 | 11:02 PM
tripleb's Avatar
There is a switch in the lf door lock assembly that sends a signal to the alarm unit to let it know you locked the car with the key. It may possibly be bad, or the wiring from it has an issue.
Old Nov 12, 2007 | 05:53 AM
PANTYEATR's Avatar
yeah, maybe there is some kind of fault cause it happends sometimes. i'll see what i can do and i'll report back.
Old Nov 12, 2007 | 03:39 PM
reg's Avatar
reg
Wait 'til you find the cost of the remote! Then after absorbing that shock................wait 'til you find the cost of programing it! I (bride) lost a remote and was surprised at the final cost............
r.
Old Nov 12, 2007 | 04:19 PM
PANTYEATR's Avatar
you can find the remotes on ebay for like $30+ and the programing is like $120 or something like that. i saw 2 new remotes go for like $46 on ebay yesterday.
Old Nov 14, 2007 | 03:06 PM
reg's Avatar
reg
I'm not a true fan of ebay. Seems most of the stuff that is sold is a Chinese fake or the product is not what is advertised. Ebay is no longer a sales depot for individuals but rather a clearing house for businesses.
r.
Old Nov 14, 2007 | 03:59 PM
PANTYEATR's Avatar
yeah, that can be the case sometimes, but you can usually spot the real and genuine sellers and products. if your not comfy with what you see on ebay, do what i do....give them a hard time.
i check feedbacks, i ask alot of questions about the item that i know the answer to already and i compare how the ad is written with other ebayers. i have over 120 positve feedbacks on both selling and buying side and i haven't had a problem yet.
Old Nov 14, 2007 | 08:04 PM
PANTYEATR's Avatar
heres an update.
i notice that if i use the power lock button inside the door, the alarm arms itself and the LED flashes. it's still not arming with the key though.
Old Nov 15, 2007 | 07:55 PM
Most likely the lock assembly (Latch assembly) is bad.
It is a big PITA to change on your car.
The entire window regulator cartridge needs to be removed.
The bottom of the regulator assembly has screws that adjust the window.
If all else fails maybe we can get together on a weekend and do it if need be.
But I can't promise you won't have windnoise when done.
The dealer will charge about 5 hours to replace it.
Old Nov 15, 2007 | 09:09 PM
PANTYEATR's Avatar
ORIGINAL: tech
wow! yeah we can do that and don't worry i already have wind noise
Old Nov 15, 2007 | 09:27 PM
ORIGINAL: PANTYEATR
ORIGINAL: tech
Ok then maybe less wind noise when we get done LOL
Call and get a price on the lock assembly you might change your mind for now.
Nic Graner
Jan 5, 2013 10:39 PM
96_civic_dx_b16
Mar 16, 2011 11:27 PM
ray hummell
Sep 30, 2005 09:22 PM
mycarl
Feb 16, 2005 05:47 PM
jayb
Aug 27, 2004 09:29 PM
