Key at 0 wiil not come out. 2001 C-70 2.3L
Old Jul 4, 2008 | 01:46 PM
MN55082's Avatar
Default Key at 0 wiil not come out. 2001 C-70 2.3L
Key stuck.
Old Jul 4, 2008 | 03:07 PM
Default RE: Key at 0 wiil not come out. 2001 C-70 2.3L
Have you pressed the shift lock button lately?
Is the shifter **** button all the way out?
Does the key turn all the way back?
Old Jul 5, 2008 | 07:30 AM
PANTYEATR's Avatar
i had the same problem and it was cause the shifter button wasent all the way out cause it was broken a lil. Tech fixed it and the car has been given me my key back ever since.
Old Jul 8, 2008 | 10:48 PM
c70convertible's Avatar
Had same problem-
spray a little WD40 at the base of the shift button and it may do the trick-
button was getting stuck closed and did not pop out. after the WD40 everything was ok and the key comes out perfect.
Saved me over $500.00 in parts and labor for a new igniton lock at dealer
good luck
peterz
Nov 12, 2010 06:13 AM
rcsoundn1
Apr 12, 2009 10:00 PM
Spbassman
Jul 14, 2007 08:59 AM
Green
Mar 22, 2007 02:20 AM
