Oil Change on 2006 C70
Old Sep 20, 2006 | 11:53 AM
casique's Avatar
Default Oil Change on 2006 C70
I have searched for this topic, but there is nothing on the new C70. So here it goes.
What type of filter does the 2006 C70 use? It looks like a replaceable filter element? Where is it? Is the car too low to drive up a metal ramp? Any special factory tools required? Thanks.
Old Sep 20, 2006 | 08:40 PM
Default RE: Oil Change on 2006 C70
I haven't had to do one yet but if it is like the S40 then it is an element.
You will need a Short 36mm socket to get the housing off.
Not sure about the Ramps though.
Old Sep 21, 2006 | 12:20 PM
casique's Avatar
Tech, is the 36mm socket a special Volvo tool, or just a a regular metric socket. Do I need a special tool to remove the filter housing?
Old Sep 21, 2006 | 08:50 PM
You can get a regular SHORT 36MM socket and thats what you use to loosen and remove the housing.
Old Sep 24, 2006 | 11:17 AM
Ihatespeedbumps's Avatar
The 36mm socket will cross reference for some Ford tools.
ThomasK
Feb 7, 2015 07:30 AM
volvoC70GA
Oct 12, 2013 06:06 PM
Mnvolvo1
Mar 25, 2008 08:42 PM
NCS60
Apr 5, 2007 12:53 AM
nationm
Feb 12, 2006 10:09 PM
