P0193 code
Old Jul 31, 2018 | 01:49 PM
RichyRich's Avatar
Default P0193 code
09 c70, P0193 code came up. Says one of the possible causes is the fuel filter. I need help FINDING the fuel filter. I looked on youtube, I have googled it. The location from youtube says its in front of the right rear tire. Not on my c70.
Where is the fuel filter located?
Old Jul 31, 2018 | 02:32 PM
tony1963's Avatar
Possible but not probable. A car that new shouldn't need a fuel filter unless it is contaminated. If you have loss of power at highway speeds or high RPMs, then maybe. I'd check other sources like the sensor on the fuel rail.
Here's where you will need a good scan tool to read live data.
Most newer vehicles have the fuel filter integrated into the fuel pump/sending unit mechanism. They are typically good for the life of the fuel pump itself.
Old Jul 31, 2018 | 04:33 PM
yep, not all newer models have a replaceable fuel filter. This code may be telling you the pressure sensor is bad - google Volvo PN# 31272732 for price/location.
Jennifer Highton
Sep 9, 2015 10:45 AM
AnEskimo
May 15, 2011 12:32 AM
vipul_vips
Nov 19, 2008 10:19 AM
kotsis
Nov 14, 2006 10:58 PM
240GL38751
Apr 19, 2004 05:04 AM
