Rear shock replacement 2006 C70
Old Jun 20, 2016 | 11:16 AM
Lovemyc70's Avatar
Default Rear shock replacement 2006 C70
Anyone out there have any accurate info on rear shock replacement on 2006 C70? Specifically I need to know where/how to access the top shock mount.
Old Jun 20, 2016 | 12:04 PM
ES6T's Avatar
Right from the wheel well. Shocks don't get any easier than on that car.
Old Aug 15, 2016 | 09:47 AM
ANJ2006C70's Avatar
ES6T - I have a local shop that doesn't know much about volvos. I have a 2006 C70. Are the shocks very straightforward for a competent mechanic? Require any special tools? I can get the OEM shocks for a good price online vs Bilstein. How long does it take to change? THANKS!
Old Aug 15, 2016 | 09:51 AM
ES6T's Avatar
No special tools. Any mechanic should have no trouble at all. They can both be done in 30 minutes no problem.
Old Aug 15, 2016 | 12:41 PM
Smith Volvo's Avatar
Banned
see attached pdf
File Type: pdf
Old Aug 22, 2016 | 11:45 AM
markap12013's Avatar
Originally Posted by Smith Volvo
see attached pdf
Hi - thanks for posting the pdf except it was for an exhaust system, not rear shocks.
A question - when I last researched this, most of the cars were older and the back seat and speakers had to be removed to get to the top of the rear shocks. I have a 2008 - is this still the case? When I opened the trunk the other day, I saw what appears to be the tops in a reasonably accessible spot.
Anyone have details for the later versions of the car (hardtop convertible).
Old Aug 22, 2016 | 12:58 PM
ES6T's Avatar
Details are already posted. You access it right from the wheel well, as I stated. Literally 3 bolts per side (two on top, one on bottom) and its out.
Old Aug 22, 2016 | 01:06 PM
Thanks! should be pretty inexpensive to get my local garage to do it. One place quoted me over $700 (including shocks) saying it was "pretty involved".
I had read the procedure for 1999's but it seemed like the 2008 was different after looking in the trunk.
Thanks for the info
greenman86
Apr 25, 2014 09:47 AM
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
paul1149
Sep 6, 2012 11:20 AM
oconnomo
Aug 7, 2009 02:05 PM
