Rear Spring Sleeve Question
Old Aug 23, 2009 | 02:26 PM
elav's Avatar
Default Rear Spring Sleeve Question
I just replaced my suspension -> Heavy Duty Blisteins, Eibach Springs and IPD anti-sway bars. I highly recommend this combo. Anyway, I've been chasing down a rattling sound after this update. My mechanic said that it wasn't the suspension because the sound couldn't be reproduced with the car not moving. To cut to the chase, after removing everything in my trunk and not getting rid of the sound I started looking under the car. I found that the nut that keeps the rear spring sleeve tight was loose and allowing the rear spring sleeve to rattle when going over bumps. At least I think it is call the rear spring sleeve (the centering part for the rear spring).
Question - I can just tighten down the nut and have it self-align, right? If not, what needs to be done?
Thanks in advance!
Alan
Old Aug 23, 2009 | 07:52 PM
Yes if you just tighten it you should be fine.
Old Aug 23, 2009 | 09:02 PM
elav's Avatar
Thanks Tech! My mechanic ripped apart the trunk when doing the install and broke a lot of the plastic fasteners in the process. Other than combing junkyards, does anyone know where to pickup these fasteners (the ones that are a push insert and a 90 degree turn to remove)?
Old Aug 24, 2009 | 06:01 AM
cb1313's Avatar
Home depot and Lowe's have a lot of plastic plugs in the hardware dept. I use them all the time and cheap. They also have some metic if you need them.
Cb
Old Aug 24, 2009 | 06:37 PM
Sorry I get them from the Dealer.
tricko82
Penta
Dec 14, 2012 10:29 AM
paul1149
Sep 6, 2012 11:20 AM
Bushbee
Aug 27, 2012 11:10 PM
pj91gsx
Sep 5, 2008 09:13 PM
moet32
May 1, 2005 01:55 AM
