recommended octane?
Old Nov 14, 2007 | 04:00 PM
PANTYEATR's Avatar
Default recommended octane?
whats the recommended octane for the C70 coupe LPT?
or
will the computer adjusttiming with whatever you put in?
Old Nov 14, 2007 | 06:06 PM
reg's Avatar
reg
Default RE: recommended octane?
You have a knock sensor that will adjust the spark (retard it) if the octane is too low. The high pressure turbo calls for premium............not sure about the low pressure. I can get by with 'regular' in my high pressure although the performance is compromised and I seldom find myself using regular. If you do not receive an answer to the grade of fuel in the next day, I'll retreive my owners manual and look it up for you.
r.
Old Nov 14, 2007 | 07:21 PM
I would use preminum or atleast swap every other tank from regular to preminum.
We have seen alot of cars with burn't valves lately which we believe is due to regular gas use when the cars require preminum.
Old Nov 14, 2007 | 08:00 PM
PANTYEATR's Avatar
yeah, i like to use premium in anything that has a turbo or supercharger or enough modifications to deem it useful to use premium. even porsche, if you put regular in it the ignition timing will be pulled way down and performance will suffer ofcourse.
today i filled up with 89 oct. cause the 93 oct. was way too high.
another question: how big is the tank on this thing? i pumped almost 15 gal. in to it and it still was wanting more [:-]
Old Nov 14, 2007 | 09:07 PM
Shaun Oriold1's Avatar
ORIGINAL: PANTYEATR
60L or 15g.
S.
Old Nov 14, 2007 | 10:25 PM
S70driver's Avatar
Premium
Old Nov 14, 2007 | 11:15 PM
PANTYEATR's Avatar
ORIGINAL: S70driver
Premium
oh boy, i hope i don't hurt nothing with all that 89 oct in there.
Old Nov 15, 2007 | 09:12 AM
S70driver's Avatar
ORIGINAL: PANTYEATR
ORIGINAL: S70driver
Premium
No you wont. I use regular mostly, but have started to use more of the middle grade now.
Old Nov 15, 2007 | 12:15 PM
reg's Avatar
reg
According to Volvo, your tank holds 17.9 gals of fuel. Volvo states in part: "Volvo engines are designed for optimum performance on unleaded premium gasoline with an octane rating of AKI 91 or above. The minimum octane requirement is AKI 87". Hopefully those quotes from Volvo will help you make your decision.
r.
Old Nov 15, 2007 | 09:18 PM
PANTYEATR's Avatar
dang! 17gal !!! thats crazy for such a small car. i just put like 4gal. of premium in to top off. this is the first time i have seen the fuel guage past "F" now i'm gonna see how many miles i can getwith this tankuntil the gas light comes on.
Old Nov 15, 2007 | 09:29 PM
My gauge never reads full LOL only reads about 17 gal when full.
I usually get about 260 to 300 out of it. My trip says 50 miles to empty when I refill.
But guage usually in the red.
Old Nov 19, 2007 | 09:28 PM
mncx's Avatar
91 or higher as always. may ping with lower octane if drive hard.
brbjab
Dec 20, 2020 08:34 AM
wmallick
Nov 16, 2009 02:04 PM
nounderscore
Feb 11, 2008 05:36 AM
wingerjw
Sep 5, 2007 09:01 PM
