rim/tire size
Old Mar 12, 2007 | 09:14 PM
ovlove's Avatar
Default rim/tire size
so its springtime and im gonna get some new shoes on the whip. What is the biggest tire and rim combo i can go with without rubbing? right now the stock 17 inch tires just look too narrow and bland.
also, are there any specific companies i should go with?
-Sam
Old Mar 12, 2007 | 09:36 PM
S70driver's Avatar
Default RE: rim/tire size
1. You need to search
2. 18 to 19 inch is the biggest I would go.
18x8 or 19x8
That is what I would go with.
If your going to run 18's, run 225/40-18 tires.
You may see rubbing on full lock.
With 19's there is bound to be more potential for rubbing all around. However you should be fine if you run the right tire.
Old Mar 12, 2007 | 09:40 PM
S70driver's Avatar
Look on...
DiscountTireDirect
TireRack
Also there are nice OEM 18" rims available as well.
VIZ1ONARY
Aug 2, 2024 06:59 PM
chadoll
Oct 20, 2009 09:28 AM
HummerGuy
Oct 10, 2008 08:02 AM
Bosanskivolvo12
Jun 13, 2007 10:29 PM
m4gician
Jan 3, 2007 02:11 PM
