Setting exhaust cam timing 1999 C70
Old Oct 28, 2008 | 09:20 PM
cederrowe's Avatar
Default Setting exhaust cam timing 1999 C70
Just did a head gasket on a 1999 c70 2.4 liter motor. Got the timing correct putting it back together but didn't get the exhaust cam seal back in correct and had to take it apart again. Now the problem, I can't seem to get the exhaust cam timing correct and need to know the timing marks on the cover conside with #1 cylinder or setting it up correctly. Volvo mechanics in my area consider this knowledge the holy grail and won't release the info!...lol Thanks for any help.
Old Oct 29, 2008 | 07:46 AM
Default RE: Setting exhaust cam timing 1999 C70
You need to lock the cams from the back side.
Is your exhaust cam the VVT one or is the Intake the VVT on yours?
Old Oct 29, 2008 | 10:03 AM
cederrowe's Avatar
yes it is the vvt exhaust version. Kind of a mute point now the cam has turned on the exhaust side. Any way of getting them back aligned?
Old Oct 29, 2008 | 10:08 AM
You need a cam lock tool to set the cams before setting the pulley.
Check out this post the guy made a home made tool for when he did his.
https://volvoforums.com/m_98892/tm.htm
Old Oct 30, 2008 | 07:51 PM
cederrowe's Avatar
Ya that write up shows how to align them before removal but what if you get them off after removal? We have our exhaust cam timing off and don't know how to get it back in time?
Old Oct 31, 2008 | 07:28 AM
But what my point is you have to lock the cams in orderto set the timing correctly.
It would be easy if you had marked the timing setup before removing everything.
But since nothing was really marked and the cams aren't locked it is almost impossible to set the timing unless the cams are locked.
If the cam and gear was keyed it would be easy.
But you have to lock the cams then do a special presidure to get it set up correctly.
tresjolie2
Nov 7, 2010 07:33 AM
jpcameron
Jul 14, 2010 09:56 AM
boxpin
Aug 7, 2009 09:25 AM
shrike
Feb 22, 2008 05:29 PM
