Sloshing Noise after rain
Old Nov 1, 2007 | 07:38 PM
newtome's Avatar
Default Sloshing Noise after rain
After a pretty heavy rain, my 99 C70 made a loud sloshing noise from the rear of the car. It actually sounded like it came from the trunk, but I checked it out and it was dry. I read something about drain holes clogging up. Does that sound right? Exactly where are the drain holes on this year/model Volvo?
I am starting to feel like I purchased a wolf in sheep's clothing! The exterior looks great, but the engine/interior are causing me headaches! Thanks to this forum I have learned how to change a fuse, put in a new air filter, and replace the cabin air filter! Recentlythe Check Engine light was on and we took it to Auto Zone and the reading was something aboutEmissions. We tried something simple like opening and closing the gas cap and then reset the light. The light stayed off until I filled the car up with gas, then it reappeared! I am thinking there is a leak in the gas tank or do any of you have any ideas?
Thanks in advance!
Old Nov 1, 2007 | 07:41 PM
Default RE: Sloshing Noise after rain
Is it a coupe or vert?
There might be a cracked line for the fuel tank vent system.
Old Nov 1, 2007 | 08:56 PM
Shaun Oriold1's Avatar
I once had a car where the wheels wells rusted through, and water would seep in, and end up in the spare tire well. It sloshed around as well, and I did not see it until I pulled the spare tire out. The musty smell gave it away though.
S.
Old Nov 5, 2007 | 05:53 AM
newtome's Avatar
tech, it is a convertible
Old Nov 5, 2007 | 05:29 PM
Look in the metal section where the top folds into with it about half way in the middle of opening or closing. You will see drains towards the front make sure they are clear.
Old Nov 28, 2007 | 11:27 PM
tlyons's Avatar
ORIGINAL: tech
Could you describe what the drains look like? I have the same problem after a rain and the sponge is getting old.
Thanks.
Tim
Old Nov 29, 2007 | 06:06 PM
Put your top about half way on the middle. So you can see the area where it lays when it is down.
On each side almost next to the seat in the hole where the top sits will be a black piece.
They are the drains.
Old Feb 12, 2008 | 10:56 AM
tlyons's Avatar
Thanks, Tech.
For anyone who winds up here from a search, on my car the drains are black, perforated, round, plastic discs and about the size of a hockey puck, one on each side of the convertible top well. To me, they didn't look like drains but my view was distorted by 3 inches of water.
I easily cleared them with a gentle push with a bathroom plunger I use to clear the drain of my bathroom sink. Once I got it, it took 15 seconds to fix.
Old May 13, 2014 | 08:04 AM
BeechCar's Avatar
I found the four black drains. the rear two were easy to clean. the hard plastic perforated disk can be pried out from the larger rubber housing. I used a wet/dry shop to vacuum out the blockage, tested with water and it works correctly.
The two forward drains are not accessible for his method. I read that if the rear wheel and plastic inner fender are removed there is access to clean the drain.
emacsp
Jan 22, 2014 12:03 AM
onur
Jan 30, 2010 02:35 PM
Volvoom
Dec 13, 2008 03:44 PM
ergatz
Feb 16, 2008 05:06 PM
djbaines
Jan 19, 2006 09:41 AM
