strange ticking noise...
Old Aug 3, 2009 | 02:06 PM
ocean238's Avatar
Default strange ticking noise...
My car is make a strange ticking noise when driving, from the driver's position i think it comes from the ETM, only happens when the car is moving or moving off, and from time to time when there's clutching action. Anyone have any idea?
It sounds a bit like the air con compressor is trying to engage the clutch, but air con is switched off and it's out of gas anyway..
the car is a C70 2.4T
Thanks
Old Aug 3, 2009 | 08:05 PM
HMM anyway you can post a sound clip of it?
Old Aug 4, 2009 | 11:02 AM
ocean238's Avatar
I will try to record something, altho is it normal that ETM makes a tick tick noise if there's something wrong?
Thank you very much tech
Old Aug 4, 2009 | 07:41 PM
When you shut it off or turn the key on it will make some noise setting itself into position.
Old Aug 4, 2009 | 11:33 PM
matt14's Avatar
Axle ping? You can remove the axle bolt and strut bolts to access the axle shaft. Add some grease to the splines. Just of your description, this is what i think. Does it happen when shifting from P-D or D-R. If so, this is more likely your problem.
Old Aug 5, 2009 | 06:45 PM
ocean238's Avatar
Mine is a manual, anyway I think you are right about the axle pinging, altho I am not sure if I want to work on that myself. How difficult is it to grease it? I fear that some damage has already been done?
Componenx
Nov 9, 2012 02:56 PM
slsnumber1
Jun 2, 2012 08:02 AM
slsnumber1
May 28, 2012 12:08 PM
VolvoS70STDturbo
Jul 12, 2008 12:42 AM
