Timing Belt Question
Old Nov 15, 2013 | 07:00 AM
Hvymtlc70's Avatar
Default Timing Belt Question
I just bought a used 2000 c70 with 90K miles. It had a check engine light. Orginal owner said the new timing belt was installed 1 tooth off and is throwing the code, and it is to much trouble to correct..and... it wont hurt anything. I confirmed the code is a timing issue. Car runs / drives fine. Mileage is excellent.
Should I worry about it??
Old Nov 16, 2013 | 05:27 AM
MSGTUSMC's Avatar
Default Timing belt
Never use old belt install new one. Always change water pump while apart if you can not confirm it has been replaced!
Old Nov 16, 2013 | 05:41 AM
Hvymtlc70's Avatar
Morning - belt and pump are new (have receipts) previous owner had a friend help him and they are 1 tooth off. Is this a big issue other than the thrown code on?>
Old Nov 17, 2013 | 03:37 AM
MSGTUSMC's Avatar
I would confirm the "one tooth off" by checking the timing. This is a ZERO interference engine, therefor it is CRITICAL the timing is correct. Valve/head job can run $3000 if interference happens! Hi revs can do it!
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
