Trans Fluid.
Old Dec 8, 2007 | 01:27 PM
Torkk's Avatar
Default Trans Fluid.
I finally found the trans dipstick. The level was good, but the color was alittle on the brown side. The car is 01 c70 5speed auto with 69k miles. Is this color normal? Or, should get the fluid changed out.
I've searched, and it seems theres no trans pan or trans filter to change out. Am I correct in thinking that?
Would a flush job and a Jiffy Lube type place be wise?
I read here to drain and fill 3 times. Why is it done that way? It does have me confused a tab.
thanx in advance
Old Dec 8, 2007 | 04:13 PM
Default RE: Trans Fluid.
The color might be a little dark.
I would stay away from Jiffy Lube.
With the low milage might not be a bad idea.
Drain and refill only does about 3.5 quarts. Thats why you need to do it atleast 3 or more times.
A full flush takes about 12 quarts.
Old Dec 8, 2007 | 04:43 PM
Torkk's Avatar
Ive always been cautious with trans flush. My reasoning always was, that the flush knocks loose little particles of clutches and clog oil passages in the trans.
Theres an aamco near by, never used em thou.
Old Dec 8, 2007 | 05:00 PM
You can do a flush your self with a clear hose. You would connect it to the top cooler hose on the Radaitor.
Put the other end of the hose into a bottle.Start the car and watch the hose for bubbles. Shut the car off when you see the bubbles. Add 2 quarts throuhg the dipstick tube. Then continue till you run 12 Quarts through the system.
Old Dec 8, 2007 | 08:51 PM
topdwn's Avatar
Hey Tech, I've got a 2000 convt. with 90,000 mi.
I asked the service guy at Volvo about a flush over 2 years ago and he said I should'nt touch it.
I've read that if you don't use the exact Volvo fluid you'll be buying a tranny soon.
Should I be concerned about getting a flush and is it true about the fluid?
I have no complaints about the way it drives right now.
Old Dec 8, 2007 | 09:12 PM
Torkk's Avatar
mobil has the fluid Mobil 3309. From what I've read its the only fluid that carrys the same spec as the fluid volvo uses, just alot more cheaper
Old Dec 8, 2007 | 09:39 PM
There is another fluid you can use. it brings up tension everytime it is talked about read this post.
https://volvoforums.com/m_35817/tm.htm
Read the entire post it is long but the point is in the end.
Old Dec 8, 2007 | 09:55 PM
topdwn's Avatar
OK, I would only use the specific Volvo fluid.
But, should I attempt the flush at all?
In the past with old domestic cars it was common to hear that if you did not regularly change trans fluid don't do it at all once it gets high miles.
The fluid is brownish, but does'nt smell burnt and as I said beforethere are no complaints about the way it currently drives.
I always try to do all necssary maint.,I'm just trying to judge the risk vs. reward of doing a flush now.
Old Dec 8, 2007 | 10:30 PM
Thats kind of how I feel.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
