turbo wategate selonoid malfunction
Old Dec 27, 2006 | 01:41 PM
ovlove's Avatar
Default turbo wategate selonoid malfunction
I forgot the number of the code.. but from time to tiem when i "shred" my car will just flutter and miss and the check engine light comes on.
I ran the obd tester and the code for selonoid malfunction came back #p0243
I have no idea where to start! any help would be great.
-Sam
Old Dec 28, 2006 | 10:17 AM
Default RE: turbo wategate selonoid malfunction
Check the boost pressure soleniod on the airbox and the hoses from it.
Old Dec 28, 2006 | 11:11 AM
ovlove's Avatar
everything looks normal.. there is a purple hose that is small and had some like grease or buildup by the clamp, it feels tight though.. i have an aftermarket manual boost controll too, could that be the problem?
Could it be the MAS?
-sam
Old Dec 28, 2006 | 11:40 AM
Could very well be.
Old Feb 19, 2007 | 11:12 AM
ovlove's Avatar
ok heres sort of an update...the cel keeps going on and off and it idles rough from time to time.. but now ive noticed whenever it shifts into overdrive i feel a couple of "thunk"s from the front end.. and if its in overdrive and i ease into the gas, the car starts shaking like mad. Is this problem related? i hope this is something simple... ive had more problems with this car than any!!
Old Feb 19, 2007 | 10:21 PM
Engine mounts ok?
Usually when the Cel flashes it means Misfire.
Old Feb 20, 2007 | 11:37 AM
ovlove's Avatar
ive talked to a few other people and they called out the cv joints or axles? i found the whole axle half shaft assy online for like 90 $. Is this a hard swap?
-Sam
Old Feb 21, 2007 | 08:48 PM
Its not that hard to swap it out.
badgers
Jan 31, 2008 05:35 AM
VBsportbiker
Apr 11, 2007 01:33 PM
imlepid
Aug 18, 2006 12:50 AM
imsasun
Nov 26, 2005 09:23 AM
sghokie
Apr 27, 2005 01:52 AM
