Two front struts for 2000 C70?
Old Aug 21, 2019 | 08:53 AM
SoDoWarts's Avatar
Default Two front struts for 2000 C70?
I recently damage one of my front struts and it has to be replaced. I was told that both have to replaced -- is that normally the case? Also, if anyone has done a front end strut replacement reccently I'd love to know what the cost was (for one or two). Thanks in advance!
Old Aug 21, 2019 | 11:28 AM
The idea of replacing both is to keep the car's handling in balance. Since the struts are considered a wear item, it makes sense to do both, then get an alignment. They are pretty easy to replace (helps to have air tools when using a spring compressor). OEM struts are Sachs which go for $80 per side, I'd also recommend new HD spring seats (use genuine Volvo) at $40/side, new bolts for the strut to knuckle $10 and new dust boot/bump stop as needed so that gets the HW total to $250-300. Add about 2 to 2.5 hours for shop time is another $250, then $100 for an alignment = $600. Doing one side may wear out tires and kicks the can down the road as you'd need to eventually do both.
jollygoodgold
Aug 31, 2012 10:45 PM
FASTER
Jan 5, 2012 07:14 PM
rmarkd
Oct 31, 2011 12:02 PM
izinux
Oct 20, 2011 02:21 PM
donzi16
May 23, 2011 06:38 AM
