XC90 Recharge Climate Conditioning when charging
Old May 16, 2023 | 11:30 AM
jtad's Avatar
Question Recharge Climate Conditioning when charging
Hey all, just got a used 2022 xc90 recharge and I am setting up the Volvo connect app for climate conditioning. Two questions,
  1. When it is charing can I use climate conditioning in the garage and door shut? As in, will it be able to heat the car without running the gas engine creating dangerous fumes? Since its summer I have experimented with cooling with out gas engine running and it, so far, has gone electric only for cooling.
  2. Can you adjust the climate temp, or is it just a fixed "comfortable" temp? It doesn't prompt or show an option to adjust the temp that you have it set to when pre-conditioning the cabin while charging.
Thanks!
Old May 16, 2023 | 11:37 AM
Dingus1's Avatar
I do not know about #1, but for #2, it is preset to 72F whether it is cooling or warming the car.
Old May 16, 2023 | 12:22 PM
philipm785's Avatar
I have a 2022 S60 Recharge and I can definitely run it safely in an enclosed space since the climate control is electric. The engine does not turn on in order to condition the cabin. This applies to both heat and cooling.
Old May 16, 2023 | 01:04 PM
jtad's Avatar
Thank you both! Is that 72 degrees adjustable?
Old May 16, 2023 | 05:42 PM
philipm785's Avatar
At least on my car, the app does not allow adjusting the pre-conditioned temperature. The manual says it is simply designed to reach a "comfortable temperature". In my experience it does a pretty good job of making the cabin comfortable in either hot or cold weather.
XC60T5
Jul 22, 2022 01:12 PM
ivanski
Apr 23, 2022 10:25 AM
KgPa
Jun 16, 2021 12:02 PM
cs9530
Jul 8, 2010 11:23 AM
skadet
Mar 30, 2009 11:18 PM
