Climate control issue
Old Apr 23, 2022 | 10:25 AM
ivanski's Avatar
Default Climate control issue
My S40 2006 cabin temperature is 5 celsius higher than the set value during cooling. Because cooling flow depends on external temperature too, the system and myself are confused a bit. When the air temperature outside is much lower than the cabin temperature the auto climate does not start the compressor instead using the outside air to cool the cabin. In Cyprus i live the sun heats up the car internal during even the coldest 3-9 celsius winter. The 5 celsius tolerance then makes problems. Is it possible to calibrate the temperature controller module?
CoKroVolvo
Feb 12, 2022 04:31 PM
cs9530
Jul 8, 2010 11:23 AM
skadet
Mar 30, 2009 11:18 PM
m1964
May 27, 2008 11:10 PM
ronski
Sep 3, 2006 10:02 AM
