03 S40 Speedo intermittent sensors ok
Old Jul 3, 2018 | 06:57 PM
dalp's Avatar
Default 03 S40 Speedo intermittent sensors ok
03 S40 Speedo works kind of intermittently. Sometimes it is working it will bounce a few times then drop to zero. Other times its at zero and you hit a good bump and it will bounce and start working. I checked the sensors and all ranged between 1772 and 1830 ohms except the driver front which read 0. I replaced and checked the new one and it registered 1772 ohms. After replacing I'm still getting the same issue. Not being a mechanic and using basic deductive reasoning, I figure it could be a cable or speedo itself??? Or something else I have no idea about. To eliminate the cables how do I check them? I should also note tach and everything else on instrument cluster works (except fuel gauge but that is another issue). There is no ABS or CEL illuminated. I checked with an OBD and no codes. I guess what I'm looking for is where do I go from here?
Old Jul 3, 2018 | 07:25 PM
tony1963's Avatar
My suggestion is to pull the cluster and send it to a repair specialist. They will check every component and reflow the solder joints which is most likely what causes the problem.
Old Jul 4, 2018 | 07:23 AM
dalp's Avatar
Thanks for the info. I'll start looking for a repair in my area.
Lima850
May 24, 2016 04:12 PM
GradyXC90
Dec 28, 2015 10:21 PM
fowler93625
Jan 29, 2014 01:20 PM
TEEKAY
Oct 25, 2013 09:18 AM
96_civic_dx_b16
Mar 16, 2011 11:27 PM
