06 S40 T5 AWD Key stuck in ignition
Old Jun 21, 2011 | 10:53 AM
mvruggink's Avatar
Default 06 S40 T5 AWD Key stuck in ignition
hey has anyone ever had any problems with the electronic key fob getting stuck in the ignition? The power stays on all the time and I have to unhook the battery cables everytime I park the car.. anyone ever experience anything like this before??
thanks!
Old Jun 21, 2011 | 11:47 AM
spark g's Avatar
Is there a small button next to the gear shifter? If so make sure it is all the way up.
Old Jun 21, 2011 | 12:44 PM
mvruggink's Avatar
it's a 6 speed.. that's only with automatics correct?
Old Nov 20, 2011 | 09:24 PM
helpmys40's Avatar
Default key stuck in 06 s40 ignition
I'm having the same problem. Key keeps sticking in the ignition. Car shuts off but interior power stays on. Sometimes it eventually clicks and releases the key, other times I have to disconnect the battery cable. Doesn't seem to have anything to do with Park. Any ideas on what I need to do? Can the mechanism that latches onto the key be bad and need replacing?
Old Nov 20, 2011 | 09:53 PM
With the 850's and S70's the shifter **** button sticks when you put it in park. Needs to be pulled out sometimes then the key releases.
Old Nov 22, 2011 | 12:00 PM
helpmys40's Avatar
I've seen a lot of posts related to gear shifter stuck. I have played with the gear shifter a lot. It doesn't seem to have anything to do with the shifter. Although I haven't ruled out a disconnect between the shifter and the ignition system. I believe there is a wire that connects the two. Also have seen threads about gunk building up in the ignition and interfering with the sensitive sensor system. I have to turn the car on and off a ton of times. Eventually, I can get it to "click" and the key will turn the rest of the way. Until I can get it to "click" the key stops just short of a full turn necessary to pull out the key. Occasionally, it doesn't "click" and I have to disconnect the battery cable for overnight. Anyone else have a strong lead so I don't waste money at a dealership????
Also, is there anywhere I can go for a schematic of how to take out the dashboard and console to expose this stuff? I grew up on a farm and am handy with tools. I'd like to try to problem solve this myself before a dealership charges $400 bucks to install a new ignition system without really knowing that that's the issue. From other Volvo blogs, that seems to be the default solution and it sometimes isn't a fix for the real problem.
Old Mar 29, 2016 | 11:41 AM
Volvo-Marshall's Avatar
I had this same problem this morning in my 2006 S40, Key would not come out of the ignition and would get stuck between the off and 1 position. I had no choice but to bring it to the Volvo dealership to get this fixed. I'm in a bind for time and I could not leave my car sitting on. They said it was the starter control unit, roughly $500 parts and labor. I love that little car so I'm willing to spend the cash to keep driving it.
Old Jun 20, 2022 | 08:12 AM
eraplai's Avatar
helpmys40, did you learn the true solution? I have the exact same problem (S40 2000).
Old Jun 20, 2022 | 04:35 PM
Reply: Dealer ended up replacing the whole mechanism.
worked fine after that. Car ended up getting totaled in an accident but performed very well with the rear collision. Very safe cars.
wish I could be more help!
Old Jun 21, 2022 | 03:41 AM
eraplai's Avatar
Thanks a lot anyways for your response!
Old Jun 21, 2022 | 11:22 AM
Sometimes the shifter release button on the handle gets stuck in or the button's linkage actually can break which doesn't allow the shif interlock to release the key. See if you can manually pop that button out. You can then spray some lubricant to allow the button to release more freely - or if broken you need to replace the button mechanism.
Old Jun 21, 2022 | 12:38 PM
eraplai's Avatar
Thanks a lot mt6120! I did put lubrikant and shifter release button feels like normal. Very smooth in and out. However I have a feeling it's the wire from shifter to the ignition lock (steering wheel lock?) that is broken somehow. So the wire is actually mounted to button (on shift side)? (I will try to get into the "buttons linkage". I have S40 year 2000. Have not found and videos or guides, so far, in how to fix it myself. I will however not pay 500-700 bucks at dealer. If it's the wire then I should be able to fix it myself. I want to fix it because total milage is only unbelievable 7.000 kilometers :-)
Old Jun 21, 2022 | 01:36 PM
if I recall, the button has a linkage that goes down the shaft of the shifter and there should be a clip to remove to pop off the handle (see if you can google for instructions - its been a while since I played with the shifter on our S40. Here's a diagram and some other parts that may be in play
https://usparts.volvocars.com/a/Volv.../GR-72772.html
Old Jun 21, 2022 | 02:08 PM
habbyguy's Avatar
There's only an electronic connection between the ignition switch and the shifter. Make sure the dash display is indicating "P" before shutting the car off to pull the key out. If it isn't, you need to figure out why - you can try "rowing" the shifter through all the positions a few times, which can (usually temporarily) "fix" flaky connections in the switch that reports on the shift lever position.
Old Jun 21, 2022 | 04:09 PM
eraplai's Avatar
thanks for kindness to help me!! Would you recognize this method?
(however in this video there does not seem to any wire linkage connecting to the **** button. Maybe it connects when clicking the **** on...) Or can it be like habbyguy (thanks u2 for help!!) says, that it is elecronic function after all. The very senior technician at Volvo dealer recalled it was a wire (about 1 meter long) as linkage on this S40 automatic year 2000 model. He was not 100% sure since it was while since he had this case.
Old Aug 18, 2022 | 04:43 AM
Blessedness Ike's Avatar
Default blessedness Ike
[QUOTE=mvruggink;277314]hey has anyone ever had any problems with the electronic key fob getting stuck in the ignition? The power stays on all the time and I have to unhook the battery cables everytime I park the car.. anyone ever experience anything like this before?
This is what I am going through right now. What do I do?
thanks​​​​​​
Obelix
Jun 20, 2022 08:40 AM
dodgerkcj
Jul 2, 2018 11:41 AM
kafrasyj
Feb 25, 2015 10:06 AM
jholling
Feb 5, 2009 11:04 PM
