2000 S40 - Cam Sensor - Seafoam
Old Mar 15, 2013 | 04:29 PM
jpjmustang's Avatar
Default 2000 S40 - Cam Sensor - Seafoam
I have the cam sensor advanced and retard - I have replaced the sensor.
Is it worth a run of seaform through the engine to see if I have too much crud in the engine (145,000 miles on the engine)?
Recommendations?
Old Mar 15, 2013 | 04:58 PM
Hudini's Avatar
It can't hurt although from what I've read it won't help either. An old mechanics trick is to run a pint of automatic transmission fluid in with the engine oil. Thins it out and has cleaning properties. You only run it that way for a day or two then change the oil and filter.
Odds are you will need either a new CVVT solenoid or CVVT gear. My guess.
Old Mar 15, 2013 | 05:35 PM
ES6T's Avatar
Yep, its never the sensor. The generic trouble code says cam sensor so the guys at Autozone doing the free scan recommend the sensor though.
newbie1962
May 29, 2015 12:55 PM
irenass80
Jul 26, 2011 07:23 PM
joe maroon 850
Apr 2, 2011 02:04 PM
Scanman
Jan 28, 2010 07:01 PM
erndawg
Feb 13, 2009 10:14 PM
