2000 S40 engine won't turn over but lights turn on
I've had a minor issue with my ignition since I got the car, specifically the key sometimes doesn't come out when I turn the car off. That hasn't really been a problem for me, but yesterday when I tried starting my car, only the lights turned on (headlights, dash lights, interior lights) and it felt like the ignition had molasses in it. The igniton won't turn with the same ease it used to, almost like how turning a steering wheel feels when you run out of power steering. The engine didn't make any noises - no clicking, just silence. Obviously it's not an issue with the battery if all my lights turn on, but my car knowledge is limited beyond that. Any ideas as to what the issue might be?
That steering column lock is held on with security bolts - the bolt heads break off when tightened - and are a little more difficult than other Volvos to get out to be able to replace the steering column lock. One method I used was to drill through the bolts from the front, cutting the bolts in half - to be able to release the column lock.
Hello. I have a 2004 S40 (New body model). I am having the issue where as described above. I receive the "Steering wheel Locked. Try again" message when I try and start the car. It is definitely the SCL (steering column lock). I have managed to get the 2 bolts out of the SCL but I cannot get the SCL to release from the column. Every video I have seen of this fix, once the bolts are out the SCL just comes right out. Is there something different with the 2004 S40 SCL and how to remove it??
