2000 S40 Vibration at high speeds
Check the rims. I have a very smooth engine, with about 105000 miles, but starting at about 75 mph I get a vibration too. When we replaced some tires I noticed that one of the rims was slightly bent from the previous owner. That may be the culprit. Good luck, and let us know!
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Others having this problem have traced it to a front drive axle, specifically either the driver or passenger side inner CV joint bad. I've never had the problem with my '01 so can't verify for certain. The fix is a new or reman half shaft. (Called drive axle, half shalf, CV shaft. Many names, all the same thing) Connects the trans to the front drive wheels, 1 on each side.
oragame
07-21-2005 11:42 PM
