2000 volvo s40 lighting issue
Old May 2, 2016 | 08:41 PM
Baby blue sedan's Avatar
Default 2000 volvo s40 lighting issue
i recently purchased an s40 from my brother for next to nothing and it had a bad headlight switch come to find out its almost $300 for a neww one so for now i wired in a toggle switch for my headlights but when i turn the toggle off as in i turn tthe headlights off my tail lights and other position lights (the litthe lights by the rear fender) turn on and stay on when the ignition is off, however if i turn the toggle back on then all the lights turn off (when the ignition is off) is this just a problem with my wireing ir does that sound like an cem (central electronics module) problem?
Old May 3, 2016 | 09:22 AM
Hudini's Avatar
Sounds like you have the light switch wired for parking lights. There is no off position on the normal light switch. The top and bottom positions are both on. The difference is whether the lights stay bright when switching to bright lights or whether they just flash bright and go back to dim when using the column mounted stalk. The middle position is for parking lights.
Old May 3, 2016 | 11:31 AM
I have a spare headlight switch for a 2000 S40 if interested... where are you located?
Old May 3, 2016 | 07:22 PM
both of my bright lights work fine and i think i should post some pics of me reduing the install of the toggle swith (should come tomorow) thanks for the help
Old May 3, 2016 | 07:26 PM
i am located in georgia (us state not the country) i an interested in your switch. send me an emai mathewreedsumner@gmail.com and we can talk about it. thanks man these are somewhat difficult to source in my area
Old May 3, 2016 | 10:57 PM
i am in georgia and i am interested
Patrick_Henry
Oct 27, 2014 06:10 AM
01s40
Oct 8, 2012 08:03 PM
SHOlvo
Jul 18, 2012 10:35 PM
quattroped
Oct 25, 2010 02:46 PM
ProBoner
Jan 9, 2009 11:32 AM
