2001 S40 front bumber splitter
Old Apr 9, 2006 | 01:40 PM
riccuk's Avatar
Default 2001 S40 front bumber splitter
I have a 2001 S40 "Sport Lux", Phase II , With its previous owners it must have had a bump on the front as I can tell that the front bumber has been replaced at some point, however they did not put the original lower splitter back on (3 part one), anyway I've been able to get one off eBay and I'm trying to attach it.
The bumper has the correct number of holes in it at the bottom and they seem to align ok. However, there is a big black plastic under tray currently attached to the underside of the bumper that seem to get in the way of the splitter, does any one have a pic of the bumper with the spliiter on that I could take a look at?? Close up under side would be great. I think the undertray might not be the original one for my bumber?
any help would be great!
Thanks
Old Apr 9, 2006 | 01:53 PM
Default RE: 2001 S40 front bumber splitter
The splitter should go under the lower cover. You should have to remove the lower cover and then reinstall. The holes for the splitter should match up with the ones for the cover.
Old Apr 9, 2006 | 02:01 PM
riccuk's Avatar
ORIGINAL: tech
Hi Thanks for the reply...
So does the lower half of the actuall bumper come off the bumper?
Old Apr 9, 2006 | 02:31 PM
Are you talking about the black molding at the bottom or the cover that goes under the engine?
The lower engine cover comes off then the moldings go on then the lower cover goes back on.
Old Apr 9, 2006 | 02:50 PM
riccuk's Avatar
The black molding at the bottom of the bumper goes about 45cm back under the engine, it has a little lip on it when viewed from the front. You can see the holes where the new splitter goes
So I guess I have to take this off first put the splitter on
Do you know if there are any diagrams on the web that would be helpful?
Old Apr 9, 2006 | 11:46 PM
Sorry no diagrams.
I would say so on taking the other off first.
But the bottom molding you posted looks like it replaces the black molding.
endneu913
Jan 31, 2014 09:54 AM
ShowTek
Feb 25, 2013 10:47 AM
LarryNH914
Aug 12, 2010 10:09 PM
russ3161
Mar 26, 2010 11:00 AM
ttesting123t
Feb 1, 2009 10:02 PM
