2001 s40 front wheel studs
Old Nov 2, 2011 | 05:30 PM
ShowTek's Avatar
Default 2001 s40 front wheel studs
So i broke one of the front wheels studs, and the shop i use, highly rated, said that the studs are all connected to the hub and that it has to be replaced all at once, costing around $729. I'm calling some bs on this since most studs can just be knocked out the back and replaced. Does anyone have experience on this?
Old Nov 2, 2011 | 09:52 PM
GerBeGurGya's Avatar
Yes the studs can in fact be replaced one at a time.
Old Nov 3, 2011 | 10:14 AM
ShowTek's Avatar
Yeah i thought it had to be BS, this pisses me off especially since they are such a highly rated shop.
Old Feb 24, 2013 | 07:15 AM
euroxepouh's Avatar
Hi Ger,
By any chance don't you have any kind of manual on replacing broken wheel stud?
Thanks in advance,
Old Feb 24, 2013 | 07:58 AM
Disco2's Avatar
Someone correct me if I'm wrong but you should just be able to knock it out with a hammer. Remove the brake caliper and rotor first. You may want to soak it with WD-40 or PB Blaster then hammer it out.
Old Feb 24, 2013 | 06:46 PM
Hudini's Avatar
I use an air hammer with the pointy tool. Takes about 5 seconds to push out the old stud.
Old Feb 25, 2013 | 06:08 AM
euroxepouh's Avatar
Thanks for the explanation.
Is it difficult to install the new one_?
Old Feb 25, 2013 | 10:47 AM
Hudini's Avatar
Not difficult really. There are a couple methods to reinstall. If you have a big enough c-clamp and socket you can push it in from the back side with the socket over the stud. Another method is to use a stack of washers and a lug nut to pull the stud through. This method puts maximum stress on the stud and threads so be careful. Use plenty of grease.
virgild
Feb 22, 2014 02:03 AM
xDread92x
May 15, 2013 06:07 AM
up2you
May 24, 2012 08:35 AM
Rob92wagon
Apr 22, 2010 06:09 PM
Sofar.
Oct 26, 2008 12:40 AM
