2001 S40 Gas tank not venting
Old Nov 4, 2013 | 12:00 PM
volvorecycle's Avatar
Default 2001 S40 Gas tank not venting
I have this s40 where when you start the car, you can hear a thumping noise coming from the gas tank. and it will continue for 20 sec after you shut it down. If you take the gas cap off, alot of pressure comes from the tank. I think the problem is with the wiring going to the diagnostic pump. If i disconnect the hose coming from the tank to the pump, I do not have the issue. I tried another known good pump and the same thing happens. So now the next step is to check the wiring. Just wondering if anyone has seen this before that can give me some tips.
4daze
Oct 26, 2012 07:05 PM
shadowfist
Mar 6, 2011 08:21 PM
guptash
Nov 25, 2008 09:39 PM
99s7o
Sep 19, 2008 06:51 PM
Dainos
Feb 11, 2008 05:33 PM
