Possible Venting Problem with a 1999 S70
Old Sep 13, 2008 | 11:57 AM
99s7o's Avatar
Default Possible Venting Problem with a 1999 S70
Recently, I had a problem with my 1999 S70. While fueling my car, the gas kicked back as if the tank were full, despite it being nearly empty. As a result, it took about twenty minutes to put fifteen gallons into the tank. Has anybody experienced this before? Could it be a problem with the air vent in the tank? Thank you so much.
Old Sep 13, 2008 | 12:39 PM
Default RE: Possible Venting Problem with a 1999 S70
Yes it most likely is but not sure where.
We have the same problem at times with customers cars but they never want to spend the money to figure it out.
Old Sep 16, 2008 | 10:48 AM
riz7's Avatar
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} There is a “filter†known as a spider trap within the fuel spout. This is most likely blocked. It happened to me last month. I took it to the dealer and they used compressed air to blow out the spout, which in turn solved the problem.
Old Sep 18, 2008 | 10:24 AM
99s7o's Avatar
we removed the flapper valve and were able to shoot compressed air through both ends of the valve. There does not seem to be any obstruction. We replaced it and still have the same problem. Is it possible there is an obstruction somewhere else between that valve and the tank?
Old Sep 19, 2008 | 06:51 PM
Did you try shooting the air into the tank through the filler neck and see if it vents out the side.
Captainkong
Sep 12, 2014 09:59 AM
volvorecycle
Nov 4, 2013 12:00 PM
shadowfist
Mar 6, 2011 08:21 PM
Pteryx
Jan 28, 2010 04:13 AM
msm15
Sep 9, 2008 05:44 PM
