2004 s40 heater core replacement
Old Feb 6, 2015 | 08:10 AM
dglee's Avatar
Default 2004 s40 heater core replacement
I need some detailed info on heater core replacement (manufacture date 5/03). I'm hoping it will be the O-rings and not the core.
David
Old Feb 6, 2015 | 10:41 AM
mf70's Avatar
O-rings are easy. There are threads on this. Heater core, not so much. Get a copy of VIDA going, and plan on a LOT of excavation, AFIK.
Old Feb 6, 2015 | 11:13 AM
dglee's Avatar
I've read plenty on O - rings, but not for the s-40. And not sure how to get "VIDA going" ... I'm new to this.
David
Old Feb 6, 2015 | 06:07 PM
Hudini's Avatar
VIDA is software for the Volvo. This would be how you look up the "how to" for replacing the o-rings leading to the heater core. It will show you step by step how to accomplish the task. It's not very consumer friendly though because it's made for the dealer, not the consumer. However, it has been hacked to allow us to use it but with some limitations. The limitations are for stuff like reprogramming ignition keys. Otherwise any thief could reprogram a key and steal your car.
VIDA is finicky to install but some clever folks have found a work around using it in a Virtual Machine. See this thread for more: http://www.matthewsvolvosite.com/for...edba06e5a24c46 This method does work. I have used it successfully on various Windows machines. No clue on Apple OS though.
I have replaced the o-rings on my 2005 but not on my 2001 so I'm no help with the earlier version.
Old Feb 7, 2015 | 06:37 AM
pierremcalpine's Avatar
David
Send me your VIN and email. I will see if I can get a vida printout for you.
Old Feb 9, 2015 | 06:54 PM
dglee's Avatar
Default vida printout
I sent the info to you privately. I would appreciate any info.
David
Old Feb 9, 2015 | 09:37 PM
TEEKAY's Avatar
I helped a friend tear out his core when he was parting out his 02.... it's buried deep in the dash where no sane man ventures willingly. Some pics from the adventure here. The dash unfortunately needs to come out if you're going there.
edit is yours nedcar or ph1?
Old Feb 10, 2015 | 12:10 PM
David
Info sent - looks like very nasty job...better make sure you have some cold beer in the fridge!
Old Feb 11, 2015 | 06:26 AM
dglee's Avatar
Received the info .. and I'm getting prepared for step one .. the fridge! Wow! It'll be a bit before I can tackle this .. thanks again for all your help.
David
rvinson2
Aug 31, 2015 07:48 AM
sweedzel
Jul 9, 2014 08:55 PM
ycartf
May 6, 2013 11:19 AM
baustin
Mar 21, 2013 10:32 PM
azeezn
Dec 12, 2005 10:50 PM
