2006 S40 stereo replacement
Old Feb 28, 2014 | 09:48 PM
llogrix's Avatar
Default 2006 S40 stereo replacement
hello there.
I would like to upgrade my stereo with a bluetooth , usb drive, and iphone connection. i been loonking all over the market and I no luck. Bestbuy tolme that they can do it and there is no radio like a Pioneer Pioneer FH-X700BT. I need help. My cd player is broken and I am tired of the radio stations
Old Mar 1, 2014 | 08:55 AM
pkrface's Avatar
IMO Crutchfield.com is the best way to shop for a stereo. You input your car info and it leads you to a list of units that work and the necessary wire harness adapters, mounting kits, etc. Doesn't mean you have to buy it there, but it will help educate you on the possibilities. You might also consider adding an aux input to allow you to play music from an ipod or mp3, which quite frankly I much prefer over a working cd player. You can find the adapter on ebay for <$70 and you can find youtube videos that show you how to pull the radio out so you can access the back to plug it in if you are moderately DIY capable. Otherwise stick with a local stereo place. Best Buy can be real hit and miss. Some of them have good installers and some don't, but generally your locally owned car audio place that only does car audio is your best bet for a quality install. In this case there are a multitude of options for equipment out there, whether it be a complete new head unit, or an adapter, but if you get a fool for an installer it won't turn out well.
Old Mar 2, 2014 | 01:08 AM
Hudini's Avatar
If your 2006 is like my 2005, there is no aftermarket replacement. At least nothing that anyone has posted here. The center display is connected to the climate controls and other functions of the car, not just the radio and CD player. Let us know if you find a solution. I want a USB port too.
Old Apr 2, 2014 | 02:05 PM
llogrix's Avatar
Thank yo so much guys.
I still looking of a solution. I took the stereo apart and it looks like that I have to cut some pieces of navy plastic inside the dashboard. There is no way that the radio I have will fit. My s40 manual stick is very unique I guess. I might just install a AUX so I can play my iPhone
Thanks again
Old Apr 3, 2014 | 08:19 AM
mf70's Avatar
In 2006, Volvo had implemented a digital format for audio - the MOST system. They also had not yet figured out that "aux-in" was a necessary part of a modern audio setup.
If your current OEM changer is bad, the Grom or Denison systems (that replace the CD changer functions inside the MOST environment) might be a choice. They are spendy (~ $3 -400), but, hey, it's a Volvo. Besides, the Volvo speaker system is glorious (IMHO), and you might as well take advantage of it.
Don't forget junk OEM radios.
Me? I used an FM modulator and the 9V connector injection point combined with Crutchfield's in-panel bluetooth dongle. Total cost, about $60.00, but I get static sometimes.
Old Apr 7, 2014 | 04:45 PM
llogrix's Avatar
Thank you guys! I love my S40 White Shark. He is giving me issues, 120k miles and I have this whistling noise coming from the engine. I looked around and I found out that the pcv syste, might be my problem..any thoughts?
Old Apr 7, 2014 | 06:49 PM
Hudini's Avatar
Does the sound change when you remove the dipstick? Yes then PCV problem. Should be fixed under an extended warranty too.
Can I ask why you posted this in a stereo thread?
Tamen13
Mar 25, 2017 10:24 PM
retrohwam
Jan 28, 2012 01:21 PM
paolet
Dec 23, 2011 11:18 AM
nkhlystov
Dec 14, 2010 01:30 AM
mikebbass
Jul 15, 2009 05:24 PM
