2007 S40 2.4 bad etm/eta
So my s40 went into "reduced power" mode yesterday on the highway. plugged in generic code reader and codes for the throttle body being stuck came back. after 2-3 mins on the side of the road it fixed itself and i managed to drive home. today it happened again but its not going away and its still acting horrible.
Hooked up vida/dice and indeed shows the eta being the problem BUT it reports its angle correctly. it just cant move on its own. there are no obstructions to the plate and it moves freely by hand. when i send the command via vida to open up to either 25% or 50% or 75% or even 100% the plate does not move. but if i move it with my hand the correct angle is then reported on vida.
question.
1. is this eta/etm swapable with another or does it need to be vin coded?
2. is there a fuse for the motor that actuates the plate?
3. Any suggestions like opening this puppy up and just swaping the motors? I know this is wishful thinking.
thank you
question.
thank you
Charles Wilson
03-31-2016 08:54 PM
