adding power to my 2003 S40
Old Apr 7, 2008 | 01:51 PM
MikMan86's Avatar
Default adding power to my 2003 S40
Does anyone know of any parts that I could purchase for my S40 that would add horsepower? I know a computer chip would do a lot, but does anyone know of any specific brands or anything that would be a good buy... also if anyone has any other suggestions I would really appreciate any help
Old Apr 10, 2008 | 09:12 AM
mcguij1's Avatar
Default RE: adding power to my 2003 S40
for any sort of serious power gains, you are talking a bit of money, for starters you can upgrade your exhaust by getting a new downpipe and catback...you can also upgrade your turbo...the ecu tuning is your last upgrade as you need to chip your computer after changing the exhaust and/or turbo...plan on spending at least 2000 for everything...
Old Apr 10, 2008 | 09:19 AM
S70driver's Avatar
Welcome to the forum.
1. What is your budget?
2. What is your Hp goal?
A. STAGE ZERO is a must and it is the first thing you need to do. STAGE ZERO refers to getting your car up to par in stock form.
B. Look at these two threads. They are linked below.
https://volvoforums.com/m_38606/tm.htm
https://volvoforums.com/m_65537/tm.htm
C. You will see the most gains with a downpipe and ECU upgrade. These are the two things you will gain the most power from doing to your car.
My recommendation would be to get a 3" mandrel bent downpipe. 2.5" mandrel bent catback system. Some type of intake even if it is just a performance panel filter and then an ECU upgrade. You will see nice gains and like the extra power. It will cost you some good money though.
VolvoS40S60
Jan 6, 2017 02:15 PM
VolvoS40S60
Mar 11, 2009 10:29 AM
07S8991
Jan 6, 2009 08:41 PM
MikMan86
Engine & Internal
Apr 10, 2008 12:44 PM
Fantasia
Dec 9, 2007 02:01 PM
