Airback indicator light
Hello,
This is my first topic as I am a new user. I wanted to say hello to everyone. Besides that I would like to ask you a question since from yesterday the airbag indicator red light remains on while the engine car is already started.
What cause this problem? What I have to do? is this iportant malfuntion? Does anyone seen this indication before?
My car is s40 2001 1.6
thanks a lot
Marios
thanks a lot
Marios
RE: Airback indicator light
The airbag light is on a different 'code' system from what I can tell so far.
I borrowed an ODBII reader to check it all out but no airbag codes. You can go to your local auto parts store/shop and they can check it in a minute or 2. I had the 'check engine light' come ona while backand it turned out to be a bad sensor. I got the code reader to figure out which sensor was bad and used the code reader to reset that code.
