Antifreeze leaking
Old Mar 24, 2012 | 07:17 PM
s40volvo's Avatar
Default Antifreeze leaking
This has been gradually happening so I brought it to the dealership and they confirmed that they dont see any leak. So my question is where is the antifreeze going?
I just filled it and travelled 6 miles and came back home and the antifreeze tank was half empty. Where is it going? I took the flashlight and looked everywhere no luck. But in the car when I drive, I was smelling antifreeze.
What gives?
Old Mar 24, 2012 | 07:57 PM
Hudini's Avatar
Sounds like a pinhole leak somewhere. Something like the turbo cooling line leaking onto the hot exhaust or similar. Maybe leave the engine running and search around til you find it. A more expensive method is using a dye that shows up under a black light.
Old Mar 25, 2012 | 01:26 PM
ed7's Avatar
ed7
If you're smelling coolant while you're in the car, you should be suspecting the heater core.
Check for wetness on the floor of the right side and also the driver's side.
Ed
bradford64
2001-2013 model year V70
13
Mar 24, 2014 12:16 PM
anjp
Jan 21, 2012 09:23 AM
alykat
Apr 7, 2011 03:06 AM
ledzep526
May 1, 2008 08:32 AM
m1964
Sep 12, 2007 09:57 PM
