blow off valves?
Old Jul 7, 2006 | 05:54 PM
zachleist's Avatar
Default blow off valves?
i have a 2001 volvo s40 turbo and i was wourding if someone make a blow off valve for it?
Old Jul 7, 2006 | 08:46 PM
S70driver's Avatar
Default RE: blow off valves?
To answer your question bluntly NO.
1. No one makes BOV kits for Volvos, that I know of.
2. You get a universal BOV and an adapter and you attach it to your car that way.
I have a 1999 s70 awd, it has a 13g turbo in it. I bought a Turbo XS Type H-RFL from a fellow Volvo owner. I had it installed by a shop for $60. They attached it to my Upper IC (Intercooler) Pipe, which by the way (Mine at least) is made from aluminum. So they used the provided aluminum adapter flange and welded it onto the pipe and put the BOV on that, tightend it down and then hooked a vaccum line up to it.
I don't know about the s40's, however I am going to guess you could possibly do the same thing. Or get a pipe that is shaped like a "T" open on all three ends, and cut your stock Upper IC hose and insert the two ends into either side of the hose, clamp them down tight so no leaking occurs. Then put the BOV on the other open end and hook a vaccum line up to it.
FYI
This picture is of mine
T-Adapter
Image found on Ebay, and used on my site for your viewing pleasure
Old Jul 8, 2006 | 12:23 PM
S70driver's Avatar
Did that help?
Turbovolv85023
Jan 3, 2008 08:13 PM
JohnS4
Apr 7, 2007 12:33 PM
c70r
Feb 7, 2006 03:25 PM
itsagirl
Jan 29, 2006 06:36 PM
cecilvaliant
Jan 27, 2004 04:41 PM
