Brake and ABS lights intermittent
Old Nov 22, 2024 | 11:14 AM
vove's Avatar
Default Brake and ABS lights intermittent
Have a 2004 s40 this is the model that is in the 2001-2004 with 1.9L turbo. Not sure if it would be different than the other s40 model that was made in late 2004. Anyway, I'm getting an intermittent Brake and ABS light on dash. At first the light was on solid and I thought I just needed to add brake fluid since the fluid was right around the min level mark. After adding the fluid I cleared all codes using a scan tool hoping to that was all I needed to be rid of this issue but the lights are coming back intermittently. Any tips on next steps to check what may be causing this issue?
Oh, I do have the dashboard issue on this car where the speedo and gas gauge works intermittently. I didn't think that would be related but then again maybe it is.
Thanks, any help much appreciated!
Old Nov 30, 2024 | 08:00 AM
richardkonrad's Avatar
What codes did you clear ? you must check what the codes are , It could be lots of things , bad abs sensor , corroded abs wheel so the senser gets bad info or even the abs unit or bad wiring
Old Dec 4, 2024 | 02:45 PM
could also be a crack in a solder joint in the ABS controller board - as noted you need to check codes. Check out Midwest ABS and XeModex's web sites for diagnostics on the controller and for a possible rebuild.
Old Feb 2, 2025 | 11:10 AM
JamieWelchahhh's Avatar
tonylinc
Sep 15, 2013 05:54 PM
Lovettdc
Feb 20, 2013 01:00 PM
xxblindxx
Sep 20, 2010 02:45 AM
dcb2271
Jan 28, 2010 06:57 PM
snulma1
Mar 19, 2007 01:05 AM
