bulb, fuse or wiring??
Old Jun 21, 2008 | 07:15 PM
miss_betty's Avatar
Default bulb, fuse or wiring??
I have a 2002 volvo s40. the drivers side low beam went out. Simple enough to fix, but when i removed the old bulb, the filament of the bulb was still intact... i replaced the bulb anyway, and it still did not work. I checked the fuse (#21) and that was intact.
Does anyone have any suggestions as to what to do next.....test the plug wiring with an meter??? i am freaking out that this is going to be expensive...
Old Jun 21, 2008 | 07:33 PM
Eric J's Avatar
Default RE: bulb, fuse or wiring??
Welcome to the forum Miss Betty.
Clean the socket with scothbrite , retry, then check for voltage at the bulb socket. (Carefull, If it's bi-xenon, the voltage is like 23K Volts) Try another bulb if it's hot.
Old Jun 21, 2008 | 08:46 PM
I would check the wiring in the headlight and for the car. Check for power to the main headlight plug first. If you have power there then check wiring to light bulb.
Old Jun 22, 2008 | 08:39 PM
chimmychong's Avatar
yea check the wiring.. my s40 was in a front drivers side collision from previous owner and my light went out a couple weeks after I bought it.... went through all the steps you did then look at my wiring and that was the problem... just rewired it and all was good
Old Jun 24, 2008 | 06:40 PM
miss_betty's Avatar
so i checked the wiring at what I Think to be the main headlight plug....it is a has a blue plastic housing??? and that had power.
i then checked the volts at the lamp and got nothing......
I unfortunately have reached the apex of my mechanical aptitude and will make an appt with my volvo mechanic....
thanks for your assistance
madymo3d
2001-2013 model year XC70
Jul 27, 2018 07:14 PM
jayson44
Apr 18, 2013 11:17 AM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
mischief4l
Sep 2, 2008 07:13 PM
