burning oil
Old Oct 2, 2008 | 03:43 AM
Keithjones1400's Avatar
Default burning oil
2004 S 40 Burning Oil - (black smoke at high revs only)
55k on clock no leaks, rattles or noises - cat was choked up now sorted
my thoughts are its probably valve seals,could it me anything more simpler?
(Just been serviced at volvo main dealer who diagnosed cat fault)
1 opinions / thoughts please
2 repair cost in uk?
cheers
Old Oct 2, 2008 | 07:47 AM
Default RE: burning oil
Black smoke means running rich not burning oil.
Blue smoke is oil.
Old Oct 3, 2008 | 08:15 AM
heheh never even thought that 1 through did I
Son has just had a new exhaust made with a sports cat, so maybe its just a diagnostic and tuning to suit new set up
(whoooopeeeeeeeee maybe he wont be coming on tap for some cash again)
Thanks a lot will post results after tuning
Old Oct 3, 2008 | 10:30 AM
Opps
garage think either valve seals or rings
£400 labour + parts for either 1
no garauntees its not the other choice if I choose to have just 1 done
so it spend £1200 or get shut i think
Old Oct 3, 2008 | 10:36 AM
Have them check the vent system first.
Old Oct 3, 2008 | 11:08 AM
(Have them check the vent system first. )
is this something i could check?
if it was mixture could it be adjusted manually or has it to be garage job
cheers
Old Oct 3, 2008 | 11:49 AM
just been out in car with r kid to see what problem is
it smokes when you change gear or accelerate hard
exhaust is very black at end and smoke seems to be blue ??
think it may be as garage said myself
going to try other garage first
maybe easier just to swap engine ?
Old Oct 3, 2008 | 01:11 PM
I highly doubt it is a major engine problem.
BLACK smoke means running rich maybe a vacuum leak or something like that.
Old Oct 29, 2008 | 11:07 AM
confirmed engine is burning oil
vent system clear
garage quote more than cars worth
priced replacement engine - still mega after spending a lot already
time to part ways - Car now sold at fraction of purchase cost and after a lot of cash spent.
Luck of the draw unfortunatley this one was a bad one and had obviously been abused prior.
Old Oct 29, 2008 | 11:20 AM
That is very odd. It really must have been beaten and overheated really bad before.
enigma9011
Sep 1, 2008 08:06 AM
mfiwd
Mar 1, 2007 11:05 PM
spandalax
Mar 23, 2005 10:49 PM
ignacio
Sep 17, 2004 03:16 PM
