A/C Compressor Clutch reshimmed?
Old Apr 7, 2017 | 08:08 AM
Andy Corwin's Avatar
Question A/C Compressor Clutch reshimmed?
Have what appears to be a common problem of the A/C blowing cold air for a few minutes then hot airfor a while. When you turn the A/C off for a few minutes and turn it back onthen it will blow cold air for a couple of more minutes then blow hotagain. I’ve done some research on this and it appears to be afairly common problem with the Volvo A/C clutches going bad andintermittently working. My problem is I can't find anyone that will make this repair - they will only replace the compressor, etc. Does anyone know of someone in the Tidewater/Hampton Roads area of Virginia (Norfolk, Chesapeake, Virginia Beach) that will do this repair?
Old Apr 7, 2017 | 06:08 PM
what year is your S40? Also have you checked the pressure of the system? As far as getting somebody to do the work, the problem is no shop wants to simply reshim and then get blamed if that doesn't do the job. You can search eBay etc for a whole replacement clutch - for about $100 or so and see if a shop will drop that in for you. At least that way you don't need to have the system opened up then recharged etc.
Old Apr 7, 2017 | 11:40 PM
Hudini's Avatar
It's super super easy. Do you have a friend with tools and like free beer?
https://volvoforums.com/forum/volvo-...shimming-6665/
On my 2005 I did not even have to remove the compressor. It's right there and easy to work on.
Old Apr 8, 2017 | 03:52 PM
pierremcalpine's Avatar
if the clips don't stay on (mine did not) just use zip ties instead.
tech
Jul 13, 2017 12:43 PM
volksnut
Aug 5, 2007 01:52 PM
hxcboatcaptain
Sep 8, 2006 02:16 PM
mrbyrd
May 31, 2006 09:43 PM
camera cart
Jun 3, 2005 03:45 PM
