Clutch main pump
Old Jul 13, 2022 | 04:47 PM
Volvotico's Avatar
Default Clutch main pump
Hello members, I have a S40 2002 and replace the whole engine, since I replace it, the clutch main pump did not have any pressure, did any of you have an idea what could be the problem?
THank you.
Old Jul 14, 2022 | 11:04 AM
by "main pump" do you mean the master cylinder? hydraulic clutches are just like brake systems - there's a master cylinder on the firewall with a fluid line that runs down to the bell housing and into a slave cylinder that actuates the clutch. If the line was removed as part of the engine replacement, the system needs to be bled to remove the air.
Shekel
Dec 4, 2021 07:34 PM
wills60r
Oct 26, 2021 03:21 PM
timwu12
Mar 2, 2015 03:31 PM
timwu12
Mar 30, 2010 01:29 PM
